xsTech Pro Mist Coolant Kit
$319.00
5 lbs.
The xsTECH Pro Mist Coolant Kit is an accessory for the xsTECH PRO desktop CNC system, designed to deliver efficient, non-fogging mist cooling for cutting metals, plastics, and composites. This kit improves tool life, surface finish, and chip evacuation, making it ideal for technical education, prototyping, and advanced machining projects.
Key Features
  • Non-Fogging Mist System: Provides targeted cooling and lubrication at the cutting tool, minimizing airborne mist for a cleaner, safer workspace.
  • 16 oz. Reservoir: Compact reservoir supports extended machining sessions without frequent refills.
  • Complete Installation Kit: Includes all necessary hardware: spray head with hosing and connectors, filter housing assembly, regulator with gauge, mounting bracket, tubing, and fasteners for easy integration with the xsTECH Pro.
  • Adjustable Flow: Integrated regulator allows precise control of mist output to match material and operation.
  • Durable Construction: Industrial-grade components ensure reliable performance in classroom or shop environments.
Benefits
  • Improves Tool Life: Reduces heat and friction at the cutting edge.
  • Enhances Surface Finish: Delivers cleaner cuts and better part quality.
  • Supports Metal Cutting: Essential for machining aluminum, brass, and other non-ferrous metals on the xsTECH Pro.
  • Easy to Install: Designed for plug-and-play integration with the xsTECH PRO enclosure and spindle head.
What's in the Box?
  • Spray head with metal hose
  • 16 oz. filter bottle/reservoir (with bracket, wrench, and screws)
  • Regulator with pressure gauge
  • Tubing (4 meters, 1/4 in. OD)
  • Fittings and connectors (PTC, brass barbs, check valve)
  • Mounting hardware (bracket, screws, washers, T-nuts)
  • Spiral wrap for tubing management
