xsTECH PRO Probing System
$249.00
The xsTECH Pro Probe is an optional XYZ touch probe accessory designed for the xsTECH PRO desktop CNC milling system. It enables automated and highly accurate workpiece setup, tool measurement, and advanced probing routines, making it ideal for technical education, prototyping, and premium hobbyist applications. The probe integrates seamlessly with the PathPilot control system.
Key Features
  • XYZ Touch Probing: Supports automated workpiece location, edge finding, and surface mapping in all three axes.
  • PathPilot Integration: Fully compatible with PathPilot’s built-in probing routines for intuitive operation and fast setup.
  • Plug-and-Play: Designed for quick installation with dedicated connectors on the xsTECH PRO. No special wiring or configuration required.
Educational & Practical Value
  • Automates Setup: Reduces setup time and increases accuracy.
  • Industry-Relevant Skills: Prepares students for modern CNC environments where probing is standard practice.
What's In The Box?
  • Probe
  • 6mm ER11 Collet
  • ISO10-ER11 Tool Holder
  • Spacer
  • Cable
  • Ring Gauge
  • Wrench
  • 123 Blocks
Specifications:
Probe Type
Normally Closed (NC) XYZ touch probe
Shaft Diameter
6 mm
Cable Length
1 meter
Connector
Pre-terminated for xsTECH PRO
