4th Axis Kit for xsTECH and xsTECH Pro Routers
$755.00
7 lbs.
The xsTECH 4th Axis Rotary Table transforms the xsTECH Pro or xsTECH from a 3-axis to a true 4-axis CNC milling system, enabling advanced machining operations such as rotary engraving, indexing, and full 4-axis contouring.
Add a 4th axis kit to your xsTECH Pro or xsTECH and get positional 3+1 and full 4th axis capabilities.
For installation instructions on xsTECH visit the xsTECH knowledgebase
Note: Only works on machines with dual DIN connections.
Key Features
  • True 4th Axis Capability: Adds a rotary (A-axis) to the xsTECH Pro or xsTECH, allowing machining of cylindrical, helical, and complex multi-sided parts.
  • Precision Workholding: Utilizes ER32 collets for secure, concentric clamping of workpieces up to 0.75 in. (19 mm) in diameter.
  • Adjustable Tailstock: Supports workpieces up to 8 in. (200 mm) in length for stable, accurate rotary machining.
  • Integrated Homing Switch: Ensures repeatable, accurate positioning and easy setup.
  • Robust Construction: Features a 70:15 pulley ratio and a 1 in. (25 mm) centerline-to-table height for optimal torque and clearance.
  • Easy Installation: Installs in minutes with included T-nuts and hardware; connects via dedicated DIN connectors on the xsTECH Pro.
  • Safety First: Designed for classroom use—requires machine power-off before connecting/disconnecting to protect electronics.
What's in the box:
  • 4th Axis Main Unit
  • Tailstock
  • Setup Bar
  • ER32 Nut
  • ER32 - 16mm Collet
  • ER32 - 20mm Collet
  • ER32 - 1/2 in. Collet
  • ER32 - 3/4 in. Collet
  • ER32 Hook Spanner
  • Wrench (38mm)
  • 5mm Hex Wrench
  • Setup Bar Tool
Specifications:
Workholding
ER32 Collets (up to 0.75 in./19 mm diameter)
Tailstock
Adjustable, supports up to 8 in. (200 mm)
Pulley Ratio
70:15
Centerline to Table
1 in. (25 mm)
Position Referencing
Integrated homing switch
Kit Weight
~7 lbs (3.2 kg)
xsTECH, xsTECH Pro (PathPilot v2.9.6+ required)
