ZA6 Robot Pneumatic Accessories Kit
$65.00
0.5 lbs.
Only 1 left
4mm pneumatic tubing and push-to-connect fittings for use with ZA6 robot solenoid valves and pneumatic grippers.
  • 1 × 4mm PU Tube(10meter)
  • 2 × PE-4(Union Tee)
  • 2 × PV-4(Elbows)
  • 2 × PY-4(Y Spliters)
  • 2 × PU-4(Straight Unions)
  • 2 × PC4-M5
  • 2 × PC4-01(1/8PT)
  • 2 × PC4-02(1/4PT)
Many ZA6 robot accessories use pneumatic pressure to actuate air cylinders. This kit of pneumatic accessories helps make connections between your compressor and various robot accessories that you may want to control pneumatically. All air fittings on Tormach robot accessories utilize 4mm pneumatic tubing. This kit provides 10m of 4mm tubing plus an assortment of pneumatic fittings to help with connections.
What’s in the box:
  • 2 × PV-4(Elbows)
  • 2 × PC4-M5
  • 2 × PC4-01(1/8PT)
  • 2 × PC4-02(1/4PT)
  • Teflon Tape
