1100M / 1100MX Stand Bundle
The 1100M / 1100MX Stand (PN: 39129) is a heavy-duty, welded-steel stand for the 1100M / 1100MX CNC mill that includes a rolling coolant tank and integrated chip drawer.
Purchase of a machine specific Chip Tray (PN: 37545 or PN: 39377) is also required.
This heavy-duty, welded steel stand provides a rigid foundation for your 1100M and 1100MX and space to safely store the PathPilot controller. Its centrally-located, rolling chip basket and coolant tank save you time between cleanouts and top-offs, as the chip basket holds up to 50 lb (20 kg) of chips, and the coolant tank holds up to 12 gal (45 L) of coolant. In addition, you can easily:
- Track coolant use with the coolant tank’s fill level gauge
- Refill the coolant tank by sliding it out from the front of the stand
- Level the machine with the stand’s adjustable feet
- Move the stand using common pallet jacks
- Some assembly required.
- 1100M or 1100MX
- PCNC 1100 (Series 1 through 3) without an enclosure
- Flood Coolant Kit (1/8 hp) (optional; not included)
What's In the Box?
NOTE: Coolant pump and hoses not included. Purchase of chip tray is also required. This item has a flat rate shipping charge inside the contiguous United States. This includes shipping to a US port of the customer's choice for freight forwarding. Destinations outside of the US will incur additional freight charges.
The stand includes:
- Coolant tank
- Leveling feet
