1100MX Extended Warranty
The 1100MX Extended Warranty is offered for the 1100MX CNC mill for a 12 month period
Limited Warranty Coverage
a. Repair or Replacement Only
d. Transferability
e. Extended Warranty Coverage
a. Coverage
b. Exclusions
- Onsite services or travel.
c. Renewal
d. Holding Period
- No warranty claims are allowed for the first 30 days following the purchase.
- The 12-month extended warranty starts after 30 days, and then warranty claims may be made at any time.
e. Fullfillment
f. Shipping
