1500MX Chip Conveyor Kit
$6,475.00
445 lbs.
Currently out of stock
1500MX Chip conveyor add-on kit for flood coolant system.
Compatability:
- 1500MX Flood Coolant required.
Keep your Tormach 1500MX mill’s chip pan clean with our new conveyor kit. The conveyor installs into the existing flood coolant tank to provide an easy to use, automatic, chip removal system. The conveyor can be activated manually by a button in PathPilot or via m-code which allows for timed, programmable control over your chip management.
See the manual for programming parameters.
Note: Photos include the 1500MX Flood Coolant Kit (PN 51567), which is required for use of the Chip Conveyor kit.
Key Benefits:
- No more worries about chip buildup in the filter baskets
- Runs on conventional, 220V power
- Programmable run duration allows coolant to drain back into the tank before discharging chips
- Replaceable Stainless Steel Chip Filter Screens
- 1CR13 Stainless Steel Conveyor Chain Belt
- Serated and Flat Wavy Cleats
- Integrated clutch system to prevent damage from jammed debris
Specifications:
- Electrical: Single Phase 220V @ 5A - ships with NEMA 6-20P plug (non-locking)
- Incline Angle: 60 degrees
- Variable speed 0.4kW Motor
- Dispense height 39 in. (99.1cm)
- Dimensions: 86.4 in. (219.6cm) Wide x 57.84 in. (146.9cm) Tall x 15.75 in. (40cm) Deep
- Shipped weight: 445 lbs
