Automatic Chip Tray Washdown Bar Kit
$1,939.00
110 lbs.
Automatic chip tray washdown kit (1/2 hp) to flush chips and swarf from the chip tray.
Coolant washdown kit sprays the chip pans with coolant to improve chip flow into the chip baskets in the coolant tank. Keeps the machine clean and prevents chip buildup in the enclosures chip pans.
Features:
  • 2x Stainless-steel coolant washdown bars
  • Five independently adjustable nozzles on each washdown bar
  • Robust, chip-tolerant coolant pump
  • Drop-in installation
NOTE: For new purchases PN 51567 Flood Coolant Kit and PN 51614, Flood Coolant Filter Assembly, 1500MX are required.
Some assembly required.
Compatibility:
  • 1500MX
What's in the Box?
  • Coolant pump
  • 2x Coolant washdown bar assemblies
  • Fittings
  • Hose
Specifications:
  • Motor Power: 1/2 hp (375 W)
  • Voltage: 230 Vac
  • Tubing Size: 3/4 in ID
