MQL Full Kit - 1500MX
MQL Kit compatible with the 1500MX only
Minimum Quantity Lubrication (MQL) replaces flood coolant with only a few ounces of naturally renewable lubricant. MQL saves money, improves tool life, and promotes cleaner shops. It also eliminates the need for fluid circulation, treatment and disposal. Plus it's an environmentally friendly product that's safe for your workers.
This MQL kit connects directly into the 1500MX controller and enables both GUI and M7 (on) / M9 (off) control from G-Code.
Benefits:
For Your Business
- Lower manufacturing costs
- Lower fluid costs
- Reduced cleaning costs
- Increased tool life
- Increased part quality
- Better scrap value
For Your Employees
- Safe, non-toxic fluids
- Less safety hazards
For the Environment
- 100% biodegradable fluid when used with supplied Coolube coolant
- Less energy consumed in the process
- Use ounces of fluid vs. gallons
What's in the box?
- Pump assembly
- Solenoid valve assembly
- Coolube, 1 gallon
Specifications:
- Air flow of 0.5 to 2.5 CFM
- Fluid adjustment
- Air adjustment
- Tough, vented 16 oz [473.2 mL] reservoir
- Heavy-duty magnetic base
Note: MQL kit does not include coolant sump or chip trays. Coolube is required for factory support.
