15L Slant-PRO Extended Warranty
$795.00
15L Slant-PRO Extended Warranty extends the Tormach warranty for 12 months on your 15L Slant-PRO Lathe
Limited Warranty Coverage
a. Repair or Replacement Only
d. Transferability
e. Extended Warranty Coverage
a. Coverage
b. Exclusions
  • Onsite services or travel.
c. Renewal
d. Holding Period
  • No warranty claims are allowed for the first 30 days following the purchase.
  • The 12-month extended warranty starts after 30 days, and then warranty claims may be made at any time.
e. Fullfillment
f. Shipping
