16-Pocket Automatic Tool Changer for the 1500MX
$6,475.00
148 lbs.
Only 1 left
The Automatic Tool Changer for the 1500MX is a 16 pocket, umbrella-style automatic tool changer for use with the 1500MX CNC mill.
This accessory is too big for parcel post and will be shipped via LTL freight.
Our automatic tool changer (ATC) is the perfect addition to your 1500MX base machine if you want to run your parts unattended. An ATC reduces repetitive motion and allows you to use your time more efficiently rather than being chained to your machine.
The PathPilot controller assigns tools to the next open position so your tool numbers can always match your CAM software without the need to manual re-order the tool numbers. It also picks the shortest direction (clockwise or counter-clockwise) when changing tools.
