24R Extended Warranty
$795.00
The 24R Extended Warranty provides an additional 12 months of warranty for your 24R CNC Router
Limited Warranty Coverage
a. Repair or Replacement Only
d. Transferability
e. Extended Warranty Coverage
a. Coverage
b. Exclusions
  • Onsite services or travel.
c. Renewal
d. Holding Period
  • No warranty claims are allowed for the first 30 days following the purchase.
  • The 12-month extended warranty starts after 30 days, and then warranty claims may be made at any time.
e. Fullfillment
f. Shipping
