AF50+ Bandsaw
$6,475.00
510 lbs.
The AF50+ Autofeed Bandsaw provides part length consistency over multiple parts and hands-free operation.
Note: This item has a flat fee shipping inside the contiguous United States. This includes shipping to a US port of customer's choice for freight forwarding. Destinations outside of the US will incur additional freight charges.
Use the AF50+ Autofeed Bandsaw to easily cut multiple parts with automatic workpiece positioning. The bandsaw’s part length consistency and hands-free operation make this an ideal companion to your CNC machine.
Features:
  • Pneumatic clamping system with adjustable soft squeeze safely holds material from thin-walled tubing to 7 in. steel round bars
  • Hydraulic feed control helps keep your blade cutting straight
  • Four blade speeds accommodate a range of material and blade styles
  • Integrated coolant system keeps your blade and workpiece cool and lubricated
  • Built-in wheels and handle allow for movement around your shop
  • Blade tension indicator for fast and easy tension adjustment after blade changes
  • Built-in display for counting down parts and troubleshooting messages
Some assembly required.
Requirements
  • Installation: Pallet jack
  • NOTE: If the ground is not smooth, you may need to use a forklift (or similar lifting equipment rated for uneven surfaces) to move the pallet(s).
  • Power and Air:
    • Primary Power: 115 Vac, 50/60 Hz, single-phase
    • Required Circuit Amperage: 15 A
    • Compressed Air Source: 90 psi to 120 psi (620 kPa to 827 kPa)
  • Space:
    NOTE: For detailed space planning information, refer to the operator’s manual.
    • Minimum Depth: 36 in. (0.91 m) plus the length of stock
    • Minimum Height: 67 in. (1.71 m)
    • Minimum Width: 60 in. (1.53 m)
What’s In the Box?
The AF50+ Autofeed Bandsaw comes with:
  • Installation tools
  • Operator manual
  • Preinstalled blade
