Air Edger
$105.00
0.6 lbs.
Nex Flow Air Edger
Nex Flow 47011-8 air edger
Model 47011 Air Edger Flat Jet air nozzle is designed to provide a powerful stream of high-velocity laminar flow and high force for blow off and cooling where air knives may not be enough.
When bench tested against several other flat jets, even those with specially designed holes or shims, the Air Edger Flat Jet outperformed them all despite whatever claims others may make. Air consumption and noise levels are minimized with its special design and configuration.
