Automatic Collet Closer for 15L Slant-PRO
$3,515.00
26 lbs.
Only 3 left
The Automatic Collet Closer for 15L Slant-PRO allows you to easily change collets and adjust clamping pressure on your lathe
Easily change collets and adjust clamping pressure on your lathe with our Automatic Collet Closer for 15L Slant-PRO. Simply thread a collet onto the draw tube, then use air pressure to adjust the clamping force. To fully automate your 15L Slant-PRO lathe, pair it with a bar puller!
Features
Requirements:
If you are looking for a Collet Closer for the 15LX Lathe - it can be found here: 15LX Collet Closer.
