Welded Bimetal Band Saw Blade, 93.25" M42 Bandsaw Blade:2362mm x 19mm x 0.9mm, 10/14 TPI 00N
$29.95
2 lbs.
Currently out of stock
Welded Bimetal M42 Band Saw Blade, 93.25 in. x 0.75 in. x 0.35 in. (2362mm x 19mm x 0.9mm), 10/14 TPI 00N
Specifications:
Blade Length 93.25 in. (2362 mm)
Blade Width 0.75 in. (19 mm)
Blade Thickness 0.035 in. (0.9 mm)
Material Bimetal
Teeth Per Inch (TPI) 10/14 TPI
Blade selection: As a general rule it is best to have at least three teeth engaged in the material being cut at all times. Therefore, if you are cutting something that is 0.33 in. thick, then a 10+TPI blade will be ideal.
