Welded Bimetal Band Saw Blade, 93.25" M42 Bandsaw Blade:2362mm x 19mm x 0.9mm, 5/7 TPI 07B
$29.95
2 lbs.
Currently out of stock
Welded Bimetal M42 Band Saw Blade, 93.25 in. x 0.75 in. x 0.35 in. (2362mm x 19mm x 0.9mm), 5/7 TPI 07B
Specifications:
| Blade Length | 93.25 in. (2362 mm) |
| Blade Width | 0.75 in. (19 mm) |
| Blade Thickness | 0.035 in. (0.9 mm) |
| Material | Bimetal |
| Teeth Per Inch (TPI) | 5/7 TPI |
Blade selection: As a general rule it is best to have at least three teeth engaged in the material being cut at all times. Therefore, if you are cutting something that is 0.33 in. thick, then a 10+TPI blade will be ideal.
