Modular Tension/Compression Tapping Head Kit
$545.00
8 lbs.
Only 2 left
TTS Modular Tension/Compression Tapping Head Kit. Includes 9 quick-change collets with adjustable slip
TTS Modular Tension/Compression Tapping Head Kit. Includes TTS chuck and 9 quick-change collets with adjustable slip.
  • Includes 9 quick change collets, acco mmodates #2 thru 1/2" (M2-M12.5) tap sizes
  • Installed Length: 5.7" (145 mm)
  • The set is compatible with both metric and inch taps manufactured to the ANSI standard.
  • Approximately Float: 0.75 in.
Note: Not compatible with PCNC 440 mills.
