Flexible Pin Spanner Wrench (2.9mm)
$18.95
0.25 lbs.
Pin Spanner Wrench. 2.9 mm pins. High carbon tool steel with vinyl dipped handle. Flexes to fit holes spaced 10 mm to 45 mm (0.39 in. to 1.77 in.)
  • Use with PN 32430, TTS .5 in. Saw Arbor
  • Use with PN 31807, TTS Modular Tapping Head Kit
Specifications:
  • Pin diameter: 2.9 mm (0.114 in.)
  • Hole spacing range: 10 mm to 45 mm (0.39 in. to 1.77 in.)
