VNMG 332 Insert 10-Pack
$185.00
0.5 lbs.
Only 1 left
The VNMG 332 Insert is an negative insert with chipbreaker that is recommended for steel roughing
Package of 10 VNMG 332 Carbide Turning Insert.
  • Designation: VNMG 332
  • Shape: 35° Rhombus (V)
  • Clearance Angle: 0° (N)
  • Tolerance: Class M (M)
  • Type: Double-Sided (G)
  • Insert I.C.:3/8" (3)
  • Thickness: 0.125" (3)
  • Corner Radius: 0.031" (2)
  • Grade (ANSI/ISO): C6/P20
  • Coating: TiN
  • Chipbreaker: Roughing
  • Application: Steel
