ZA6 Robot Extended Warranty
The ZA6 Robot Extended Warranty Provides an extended 12 months of warranty on electrical components for your robot.
Limited Warranty Coverage
a. Repair or Replacement Only
d. Transferability
e. Extended Warranty Coverage
a. Coverage
b. Exclusions
- Onsite services or travel.
c. Renewal
d. Holding Period
- No warranty claims are allowed for the first 30 days following the purchase.
- The 12-month extended warranty starts after 30 days, and then warranty claims may be made at any time.
e. Fullfillment
f. Shipping
