Automatic Collet Closer for 8L Lathe
$3,150.00
22.5 lbs.
Only 5 left
The Automatic Collet Closer for the 8L Lathe provides air-actuated clamping for standard 5C collets. Clamping force is set by regulating input air pressure, allowing repeatable and adjustable part retention without manual drawtube operation.
Included Components:
- Automatic Collet Closer assembly
- Mounting hardware for 8L Lathe
- FRL unit
Requirements:
- PathPilot v2.0.2 or later
- Clean, filtered, pressure-regulated compressed air supply (Example: California Air Tools 4610S or equivalent)
