LUBE CUBE Coolant Kit (115 Vac) for 770M / 770MX*
$395.00
9 lbs.
Only 1 left
Reduce coolant waste and eliminate hazardous fog with the LUBE CUBE fogless coolant sprayer system. This HVLP (High Volume, Low Pressure) minimum-quantity lubrication (MQL) system delivers a precisely targeted spray directly to the cutter and workpiece—without finely atomizing coolant into airborne mist.
Designed to improve shop air quality while maintaining effective lubrication, the LUBE CUBE uses a controlled, high-volume air stream to clear chips and apply coolant exactly where it’s needed.
Features include:
  • Fogless HVLP spray design to reduce airborne coolant and overspray
  • Targeted lubrication for improved tool life and cutting performance
  • Adjustable coolant flow for a wide range of machining conditions
  • Integrated solenoid valve for instant on/off control via M-code command in PathPilot
  • Transparent reservoir for easy coolant level monitoring
  • Compact mounting solution for clean installation and positioning
Some assembly required.
Compatibility:
  • 770M
  • 770MX sold before December 1, 2025 with serial number beginning with MF or MH
  • MQL-safe coolant
Requirements:
  • 0.5 gal (1.9 L) MQL-safe coolant (not for use with pure water, alcohols, or other solvents)
  • 20 psi to 120 psi (140 kPa to 840 kPa) compressed air source
  • Operating CFM 0.7 - 2.0 CFM
What’s in the Box?
  • Coolant reservoir
  • Mounting bracket
  • Precision spray nozzle
  • Pneumatic lines
  • Pressure regulator
  • Solenoid valve (pre-assembled)
*Not compatible with 770MX mills sold after December 1, 2025 with serial numbers beginning with ML.
