PCNC 440 Power Drawbar Kit
$1,259.00
19.5 lbs.
The Power Drawbar Kit supplies a pneumatic power drawbar that increases productivity and efficiency through push-button tool changes - for use with and without 440 ATC
Manually changing your Tormach Tooling System (TTS) tools takes time and effort, which reduces productivity. Instead, use the pneumatic power drawbar for lightning-fast, push-button tool changes to keep you making chips, not spinning wrenches. For use with 440 ATC.
Features:
- Floating pneumatic cylinder unclamps tools without stressing spindle bearings
- Easy installation kit has the drawbar up and running in minutes
Some assembly required.
- PCNC 440
- Tormach Tooling System (TTS) tools
Requirements
- 90 psi to 120 psi (620 kPa to 840 kPa) compressed air source
What’s In the Box?
- Cylinder assembly
- Valve assembly
- Pneumatic lines
- 1/4 in. industrial-shape, quick-connect coupling
- FRL - Filter-Regulator-Lubricator
