12-Pocket Automatic Tool Changer Kit for PCNC 1100 Series 2 or 3
$6,475.00
88.5 lbs.
Only 1 left
The ATC Kit for PCNC 1100 features a 12-pocket, umbrella-style Automatic Tool Changer (ATC) for use with the PCNC 1100 series 2 or series 3 CNC mill
Eliminate the need for manually changing tools with our Automatic Tool Changer (ATC). This is our modern ATC, along with a retrofit kit to interface it with your PCNC mill, the ATC features:
- 12-station tool tray for Tormach Tooling System (TTS) tool holders
- Air blast to clear chips from tools
- Automatic crash detection and warning prompts
- Carousel position feedback
- Integrated touch-off routine (requires Electronic Tool Setter )
Some assembly required.
- PCNC 1100 Series 2
- PCNC 1100 Series 3
- Tormach Tooling System (TTS) tool holders
If you need an ATC for an 1100M please see PN 38400
Requirements
- Dry and lubricated compressed air between 90 to 120 psi (we recommend FRL Filter-Regulator-Lubricator and California Air Tools 4610S Air Compressor )
- Power Drawbar (not included)
- PathPilot 2.0 or greater (not included)
What's In the Box?
- Mounting hardware
