CHANGE TOOL NUMBER (T)
It’s your responsibility to make sure that the carriage is in a safe place for changing tools (for example, by using G30). This allows optimization of motion which can save time. A pause for manual intervention can always be provided by an M00 or M01 before the tool change.
TROUBLESHOOTING
It’s an error if:
- A negative T number is used
- A T number larger than 54 is used
- Introduction
- Programming Overview
- Programming G-Code
- Rapid Linear Motion (G00)
- Dwell (G04)
- Set Offsets (G10)
- Length Units (G20 and G21)
- Straight Probe (G38.x)
- Absolute Coordinates (G53)
- Distance Mode (G90 and G91)
- Programming Canned Cycles
- Programming M-Code
- Supported M-Codes Reference
- Tool Change (M06)
- Feed Override Control (M50)
- Wait on Input (M66)
- Programming Input Codes
- Advanced Programming
