PROGRAMMING INPUT CODES
UNLOCK YOUR MACHINE'S FULL POTENTIAL
Our on-site training brings expert instructors straight to you with training tailored to your machine, your workflow, and your team.
Welcome to our PathPilot video series! Whether you’re new to CNC or just PathPilot, these videos cover setup, basic controls, and running your first programs to help you get started with confidence.
- Introduction
- Programming Overview
- Programming G-Code
- Rapid Linear Motion (G00)
- Dwell (G04)
- Set Offsets (G10)
- Length Units (G20 and G21)
- Straight Probe (G38.x)
- Absolute Coordinates (G53)
- Distance Mode (G90 and G91)
- Programming Canned Cycles
- Programming M-Code
- Supported M-Codes Reference
- Tool Change (M06)
- Feed Override Control (M50)
- Wait on Input (M66)
- Programming Input Codes
- Advanced Programming
