FUNCTIONS REFERENCE
The available functions are:
- ATAN[Y]/[X]: Four quadrant inverse tangent
- ABS[arg]: Absolute value
- ACOS[arg]: Inverse cosine
- ASIN[arg]: Inverse sine
- COS[arg]: Cosine
- EXP[arg]: e raised to the given power (ex)
- FIX[arg]: Round down to integer
- FUP[arg]: Round up to integer
- ROUND[arg]: Round to nearest integer
- LN[arg]: Base-e logarithm
- SIN[arg]: Sine
- SQRT[arg]: Square root
- TAN[arg]: Tangent
- EXISTS[arg]: Check named parameter
- Introduction
- Programming Overview
- Programming G-Code
- Rapid Linear Motion (G00)
- Dwell (G04)
- Set Offsets (G10)
- Length Units (G20 and G21)
- Straight Probe (G38.x)
- Absolute Coordinates (G53)
- Distance Mode (G90 and G91)
- Programming Canned Cycles
- Programming M-Code
- Supported M-Codes Reference
- Tool Change (M06)
- Feed Override Control (M50)
- Wait on Input (M66)
- Programming Input Codes
- Advanced Programming
