SUBROUTINES REFERENCE
Subroutines are identified in a program by a unique subroutine label. The subroutine label is the letter O followed by an integer (with no sign) between 0 and 99999 written with no more than five digits (000009 is not permitted, for example) or a string of characters surrounded by <> symbols.
Examples of valid subroutine labels include:
  • O123
  • O99999
  • O
Subroutine labels may be used in any order but must be unique in a program. Each subroutine label must be followed by a subroutine keyword.
The subroutine keyword defines the action associated with the subroutine label. Valid subroutine keywords and their meanings are as follows:
  • Call: Call the subroutine
  • Return: Return a value
The sub and endsub keywords are used to define the beginning and end a subroutine. All lines of code between the sub and endsub keywords are considered to be part of the
subroutine.
Example of sub, endsub, call:
o100 sub
o100 endsub
M02
Subroutines can either be defined in the program file or in a separate file. If the subroutine is defined in the same file as the main program that calls the subroutine, it must be defined before the call statement. For instance, this is valid:
o100 sub
o100 endsub
M02
But this is not:
M02
o100 sub
o100 endsub
A subroutine can be a separate file, provided the following rules are obeyed:
  • The file must be named the same as your call.
  • The file must include a sub and endsub in the file.
  • The file must be in the directory /subroutines.
  • The file name can include lowercase letters, numbers, dashes, and underscores only.
  • The file can contain only a single subroutine definition.
  • The file must end with the extension .nc.
To execute a subroutine in a program, it must be called. To call a subroutine, program O~ call where ~ is the subroutine name. The subroutine name may be either a named file, a numbered file, or an expression that evaluates to a valid subroutine label.
Expression example: o[#101+2] call
Named file example: o call
Numbered file example: o123 call
O~ call takes up to 30 optional arguments, which are passed to the subroutine as #1, #2 , . . . , #N. Unused parameters from #N+1 to #30 have the same value as in the calling context.
Subroutine bodies may be nested. Nested subroutines may only be called after they are defined. They may be called from other functions, and may call themselves recursively if it makes sense to do so. The maximum subroutine nesting level is 10.
NOTE: File names are lowercase letters only. o < MyFile > is converted to o < myfile > by the interpreter.
