LENGTH UNITS (G20 AND G21)
Tip! Program either G20 or G21 near the beginning of a program, before any motion occurs. Avoid using either one anywhere else in the program. It’s your responsibility to make sure that all numbers are appropriate for use with the current length units.
- Introduction
- Programming Overview
- Programming G-Code
- Rapid Linear Motion (G00)
- Dwell (G04)
- Set Offsets (G10)
- Length Units (G20 and G21)
- Straight Probe (G38.x)
- Absolute Coordinates (G53)
- Distance Mode (G90 and G91)
- Programming Canned Cycles
- Programming M-Code
- Supported M-Codes Reference
- Tool Change (M06)
- Feed Override Control (M50)
- Wait on Input (M66)
- Programming Input Codes
- Advanced Programming
