The store will not work correctly when cookies are disabled.
SUPPORTED G-CODES REFERENCE
- G00: Rapid positioning
- G01: Linear interpolation
- G02: Clockwise circular interpolation
- G03: Counter-clockwise circular interpolation
- G04: Dwell
- G07, G08: Diameter / radius mode
NOTE: The Tormach 15L and Rapid Turn both use G7 (X positions displayed in diameter values). G8 is not used or supported in PathPilot.
- G10 L1: Set tool table entry
- G10 L10: Set tool table – calculated – workpiece
- G10 L11: Set tool table – calculated – fixture
- G10 L2: Set work offset origin
- G10 L20: Set work offset origin – calculated
- G17, G18, G19: Plane selection
- G20/G21: Inch / millimeter unit
- G28: Return home
- G28.1: Reference axes
- G30: Return home
- G33: Spindle sync. motion (like threading)
- G33.1: Rigid tapping
- G40: Cancel cutter radius compensation
- G41/G42: Start cutter radius compensation left / right
- G41.1, G42.1: Dynamic Cutter Compensation
- G43: Apply tool length offset
- G49: Cancel tool length offset
- G53: Move in absolute machine coordinate system
- G54: Use fixture offset 1
- G55: Use fixture offset 2
- G56-G58: Use fixture offset 3, 4, 5
- G59: Use fixture offset 6 / use general fixture number
- G61/G61.1: Path control mode
- G64: Path control with optional tolerance
- G73: Canned cycle – peck drilling
- G76: Multi-pass threading cycle
- G80: Cancel motion mode (including canned cycles)
- G81: Canned cycle – drilling
- G82: Canned cycle – drilling with dwell
- G83: Canned cycle – peck drilling
- G85: Canned cycle – boring, no dwell, feed out
- G86: Canned cycle – boring, spindle stop, rapid out
- G88: Canned cycle – boring, spindle stop, manual out
- G89: Canned cycle – boring, dwell, feed out
- G90, G90.1: Absolute distance mode
- G91,G91.1: Incremental distance mode
- G92: Offset coordinates and set parameters
- G92.x: Cancel G92, etc.
- G93, G94, G95: Feed modes
- G96, G97: CSS, RPM modes
- G98: Initial level return / R-point level after canned cycles
