PROGRAMMING G-CODE
- Rapid Linear Motion (G00)
- Dwell (G04)
- Set Offsets (G10)
- Length Units (G20 and G21)
- Straight Probe (G38.x)
- Absolute Coordinates (G53)
- Distance Mode (G90 and G91)
ABOUT THE EXAMPLES USED
- Axis words specify a destination point
- Axis words relate to the currently active coordinate system, unless explicitly described as being in the absolute coordinate system
- Where axis words are optional, any omitted axes retain their current value
