DYNAMIC CUTTER COMPENSATION (G41.1 AND G42.1)
- D~ is the tip radius multiplied by two
TROUBLESHOOTING
It’s an error if:
- Cutter Compensation is commanded to turn on when it is already on
- Introduction
- Programming Overview
- Programming G-Code
- Rapid Linear Motion (G00)
- Dwell (G04)
- Set Offsets (G10)
- Length Units (G20 and G21)
- Straight Probe (G38.x)
- Absolute Coordinates (G53)
- Distance Mode (G90 and G91)
- Programming Canned Cycles
- Programming M-Code
- Supported M-Codes Reference
- Tool Change (M06)
- Feed Override Control (M50)
- Wait on Input (M66)
- Programming Input Codes
- Advanced Programming
