SUPPORTED M-CODES REFERENCE
  • M00: Program stop
  • M01: Optional program stop
  • M02: Program end
  • M03/M04: Rotate spindle clockwise/counterclockwise
  • M05: Stop spindle rotation
  • M06: Tool change
  • M07/M08: Coolant on
  • M09: All coolant off
  • M10/M11: Unclamp/clamp automatic collet closer (8L,15L) / Dust shoe/open-close collet (24R)
  • M19: Orient spindle
  • M27/M28: Dust Shoe (24R)
  • M29: Axis unwind
  • M30: Program end and rewind
  • M44/M45: Probe on-off
  • M46/M47: ETS on-off
  • M48: Enable speed and feed override
  • M49: Disable speed and feed override
  • M50: Feed override control
  • M51: Spindle override control
  • M52: Adaptive feed control
  • M53: Feed stop control
  • M59: Smoothing
  • M60: Pallet change pause
  • M61: Set tool number
  • M64: Activate output relays
  • M65: Deactivate output relays
  • M66: Wait on an input
  • M67/M68: Analog output control
  • NOTE: M64 through M66 is only useful with a USB M-Code I/O Interface Kit (PN 32616).
  • M70: Save Modal State
  • M71: Invalidate stored modal state
  • M72: Restore modal state
  • M73: Save autostore modal state
  • M83: Clear remap start line
  • M98: Call subroutine
  • M99: Return from subroutine/repeat
  • M101-M109: User Defined M-Codes
  • M101-M199: User Defined M-Codes
  • M207: TSC on
  • M208: Washdown pump on(1500MX) / Cut height(1300PL)
  • M209: All aux coolant off
  • M210: TSC off(1500MX) / THC volts(1300PL)
  • M231/M233: Chip conveyor on/off
  • M301/M302: Video recording start/stop
  • M303: Take picture
  • M400/M401: G-Code flag clear/set
  • M740: Program stop callback
  • M998: Alias for G30
